Both sides previous revision Previous revision | |||
fcs:cepc:intro [2016/04/08 16:54] asc [Wired Visualization] |
Line 130: | Line 130: | ||
You will see the detector layout. | You will see the detector layout. | ||
- | Now, we will read the event: Open any *.slcio file you copied from HepSim as | + | Now, we will visualize a single |
**[File]-[Open data source]-[LCIO]** file. Then click a small button [Go] (top menu bar). It will process | **[File]-[Open data source]-[LCIO]** file. Then click a small button [Go] (top menu bar). It will process | ||
