fcs:eic:intro [2016/11/06 03:07] asc |
fcs:eic:intro [2016/12/09 16:33] asc [Hit timing information] |
Line 110: | Line 110: | ||
Note that the plot is done for all electrons starting from 1 GeV (a region where the efficiency is quite small). | Note that the plot is done for all electrons starting from 1 GeV (a region where the efficiency is quite small). | ||
+ | ===== Hit timing information ===== | ||
+ | You can also look at timing of silicon tracker using this script: {{: | ||
+ | <code bash> | ||
+ | hs-get pgun_elec_eta4_pt30gev%rfull052 data # 2 100 get 100 files in 2 threads in the directory " | ||
+ | fpad eic: | ||
+ | The plot is shown here: | ||
====== Looking at track resolution ====== | ====== Looking at track resolution ====== | ||
You can also look at single particles with flat pT, Eta and Phi. Here is an example this using a simple validation script {{: | You can also look at single particles with flat pT, Eta and Phi. Here is an example this using a simple validation script {{: | ||
- | for the MCparticle container inside LCIO file: | + | for the MCparticle container inside LCIO file. We will use the "flat pT" sample called [[http:// |
Line 126: | Line 138: | ||
Now, let's calculate track resolution. We will use this script {{: | Now, let's calculate track resolution. We will use this script {{: | ||
- | makes fit of pT(reco)/ | + | makes fit of pT(reco)/ |
+ | This command shown below makes resolution plots, fits with a Gaussian function, and plot resolution as a function of pT: | ||
+ | hs-get pgun_elec_eta4_pt30gev%rfull052 data 2 20 # get 20 files in 2 threads in the directory " | ||
+ | fpad track_resolution.py | ||
+ | The final plot is shown below: | ||
Line 150: | Line 169: | ||
- | wget http:// | + | wget http:// |
