User Tools
Site Tools
fcs:eic:intro
Differences
Link to this comparison view
Next revision
Previous revision
fcs:eic:intro [2016/11/06 16:31]
asc [Looking at track resolution]
fcs:eic:intro [2016/12/09 16:34]
asc [Hit timing information]
Line 110: Line 110:
 Note that the plot is done for all electrons starting from 1 GeV (a region where the efficiency is quite small). Note that the plot is done for all electrons starting from 1 GeV (a region where the efficiency is quite small).
 +====== Hit timing information ======
 +You can also look at timing of silicon tracker using this script: {{:fcs:eic:mc_hits_time.py|eic:mc_hits_time.py}}
 +<code bash>
 +hs-get pgun_elec_eta4_pt30gev%rfull052 data # 2 100  get 100 files in 2 threads in the directory "data"
 +fpad eic:mc_hits_time.py
 +</code>
 +The plot is shown here:
 +{{:fcs:eic:electrons_hit_timing.png?400|}}
 ====== Looking at track resolution ====== ====== Looking at track resolution ======
 You can also look at single particles with flat pT, Eta and Phi. Here is an example this using a simple validation script {{:fcs:eic:mc_truth_flat.py|}} You can also look at single particles with flat pT, Eta and Phi. Here is an example this using a simple validation script {{:fcs:eic:mc_truth_flat.py|}}
-for the MCparticle container inside LCIO file. We will use the "flat pT" sample called [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=242|pgun_elec_eta4_pt30gev]] reconstructed with the tag "rfull052":+for the MCparticle container inside LCIO file. We will use the "flat pT" sample called [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=242|pgun_elec_eta4_pt30gev]] reconstructed with the tag "rfull052" (SiEIC with 1T solenoid):
 <code bash> <code bash>
Line 157: Line 171:
-wget http://mc.hep.anl.gov/asc/hepsim/events/misc/pgun/pgun_eta45_p30_elec//rfull051/pgun_elec30gev_001_pandora.slcio+wget http://mc.hep.anl.gov/asc/hepsim/events/misc/pgun/pgun_eta45_p30_elec/rfull051/pgun_elec30gev_001_pandora.slcio
 </code> </code>
fcs/eic/intro.txt ยท Last modified: 2016/12/09 16:34 by asc
