fcs:fcchh:intro [2016/03/30 02:37] asc [FCC-hh detector studies: Software and detectors] |
fcs:fcchh:intro [2016/09/23 21:45] asc |
Line 7: | Line 7: | ||
This wiki describes physics studies for a FCC-hh detector. | This wiki describes physics studies for a FCC-hh detector. | ||
- | You can find Monte Carlo samples in the LCIO format using the [[http:// | ||
- | This link prints all event samples after full detector simulations ("tag rfull005" | ||
- | Select " | ||
You can download such samples as discussed in [[http:// | You can download such samples as discussed in [[http:// | ||
+ | This wiki is rather generic, but the detector is still evolving. So, please pay attention to the detector we are using for the ongoing studies. | ||
+ | <note tip> | ||
+ | The current FCC-hh detector is **sifcch7**. It is a compact high-segmented detector based on SiD. You can find this detector | ||
+ | in the [[http:// | ||
+ | Look for **sifcch7.zip** file. This detector corresponds to [[http:// | ||
+ | The description of this detector is [[http:// | ||
Line 32: | Line 41: | ||
* Visualisation of reconstructed events using Wired4 display | * Visualisation of reconstructed events using Wired4 display | ||
- | You can find more details in [[http:// | + | You can find more details in [[asc: |
- | All examples for this page are located in the " | + | |
- | <note tip> | ||
- | The current FCC-hh detector is **sifcch4**. It is a compact high-segmented detector based on SiD. You can find this detector | ||
- | in the [[http:// | ||
- | Look for **sifcch4.zip** file. | ||
Line 110: | Line 109: | ||
====== Wired Visualization ====== | ====== Wired Visualization ====== | ||
- | ====== Detector geometry ====== | ||
- | The current version of the FCC-hh | + | The current version of the FCC-hh detector is located |
- | You can study this geometry using [[http:// | + | zip file with your detector, say |
- | [[http:// | + | You can study this geometry using the " |
- | Note that only barrel region |eta|< | + | |
- | To visualize this detector, use Wired4: | + | To visualize this detector, use Wired4. Download the " |
- | wget http:// | + | jaspp detector.heprep |
- | jaspp sifcch3.heprep | + | |
Line 127: | Line 123: | ||
- | You can run Jas+Wired to visualize the simulated events. | ||
- | <code bash> | ||
- | jaspp sifcch4.heprep | ||
- | The file sifcch4.heprep can be found inside sifcch4.zip file located in the [[http:// | ||
Alternatively, | Alternatively, | ||
You will see the detector layout. | You will see the detector layout. | ||
Line 151: | Line 141: | ||
====== Visualizing geometry using ROOT ====== | ====== Visualizing geometry using ROOT ====== | ||
- | (contribution | + | (contribution |
You can also visualize the detector using ROOT. Here are a few steps: | You can also visualize the detector using ROOT. Here are a few steps: | ||
- | Locate the file sifcch4.gdml inside | + | Locate the file detector.gdml inside |
+ | This file is created using | ||
slic -g detector.lcdd -G detector.gdml | slic -g detector.lcdd -G detector.gdml | ||
Once you have the GDML file, you can use ROOT to visualize it. You just | Once you have the GDML file, you can use ROOT to visualize it. You just | ||
Line 165: | Line 158: | ||
At the ROOT prompt do: | At the ROOT prompt do: | ||
- | TGeoManager:: | + | TGeoManager:: |
gGeoManager-> | gGeoManager-> | ||
- | This should popup an OpenGL | + | This should popup an OpenGL |
- | clip, pan, rotate etc. | + | clip, pan, rotate etc. See this image: |
====== People ====== | ====== People ====== | ||
