User Tools
Site Tools
fcs:fcchh:intro
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
fcs:fcchh:intro [2016/03/30 02:39]
asc [FCC-hh detector studies: Software and detectors]
fcs:fcchh:intro [2016/04/02 01:16]
Line 7: Line 7:
 This wiki describes physics studies for a FCC-hh detector. This wiki describes physics studies for a FCC-hh detector.
-You can find Monte Carlo samples in the LCIO format using the [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull005|rfull005 search link]].
- This link prints all event samples after full detector simulations ("tag rfull005").
-Select "info" and then find the tag "rfull001" which  prints LCIO files for a given MC sample.
 You can download such samples as discussed in [[http://atlaswww.hep.anl.gov/hepsim/description.php|HepSim manual]]. You can download such samples as discussed in [[http://atlaswww.hep.anl.gov/hepsim/description.php|HepSim manual]].
 +This wiki is rather generic, but the detector is still evolving. So, please pay attention to the detector we are using for the ongoing studies.
 +<note tip>
 +The current FCC-hh detector is **sifcch4**. It is a compact high-segmented detector based on SiD. You can find this detector
 +in the [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|detector repository]].
 +Look for **sifcch4.zip** file. This detector corresponds to [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull006|rfull006 tag]] SLCIO  files in HepSim.
 +The description of this detector is [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.html|here]].
 +</note>
Line 32: Line 41:
   * Visualisation of reconstructed events using Wired4 display   * Visualisation of reconstructed events using Wired4 display
-You can find more details in [[http://atlaswww.hep.anl.gov/hepsim/description.php|HepSim manual]]+You can find more details in [[asc:jas4pp|Jas4pp manual]]. The example showing how to run over SLCIO files using [[https://atlaswww.hep.anl.gov/asc/jas4pp/|Jas4pp]] are located in the "examples/slic" directory of the Jas4pp package.
-All examples for this page are located in the "examples/slic/" directory.+
-<note tip>
-The current FCC-hh detector is **sifcch4**. It is a compact high-segmented detector based on SiD. You can find this detector
-in the [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|detector repository]].
-Look for **sifcch4.zip** file. This detector corresponds to [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull006|rfull006 tag]] SLCIO  files in HepSim.
-</note>
Line 110: Line 109:
 ====== Wired Visualization ====== ====== Wired Visualization ======
-====== Detector geometry ======
 The current version of the FCC-hh detector is located in the [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|detector repository]]. Find the The current version of the FCC-hh detector is located in the [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|detector repository]]. Find the
-zip file with your detector, say  "detector.zip" file. +zip file with your detector, say  "detector.zip" file ("detector" is the actual name of your detector)
-You can study this geometry using the description link. This geometry corresponds to +You can study this geometry using the "descriptionlink.
-Note that only barrel region |eta|<1.7 is currently works, so you would need to set a cut |eta|<1.2 for jets to avoid end-cap regions.+
-To visualize this detector, use Wired4:+To visualize this detector, use Wired4. Download the "detector.zip" file, unpack and locate the file "detector.heprep". Then run it as:
 <code bash> <code bash>
-wget http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch4/sifcch4.heprep +jaspp detector.heprep
-jaspp sifcch3.heprep+
 </code> </code>
Line 128: Line 123:
-You can run Jas+Wired to visualize the simulated events.  The Wired program is included in the Jas4pp program, so you simply run it as:
-<code bash>
-jaspp sifcch4.heprep
-</code>
-The file sifcch4.heprep can be found inside sifcch4.zip file located in the [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/|detector repository]].
 Alternatively, visualize the detector as **[File]-[Open data source]-[HepRep]** XML. Alternatively, visualize the detector as **[File]-[Open data source]-[HepRep]** XML.
 You will see the detector layout. You will see the detector layout.
Line 152: Line 141:
 ====== Visualizing geometry using ROOT ====== ====== Visualizing geometry using ROOT ======
-(contribution from N.Nikiforou):+(contribution by N.Nikiforou):
 You can also visualize the detector using ROOT. Here are a few steps: You can also visualize the detector using ROOT. Here are a few steps:
-Locate the file sifcch4.gdml inside sifcch4.zip. This file is created using+Locate the file detector.gdml inside detector.zip.
 +<hidden>
 +This file is created using
 <code> <code>
 slic -g detector.lcdd -G detector.gdml slic -g detector.lcdd -G detector.gdml
 </code> </code>
 +</hidden>
 Once you have the GDML file, you can use ROOT to visualize it. You just Once you have the GDML file, you can use ROOT to visualize it. You just
Line 166: Line 158:
 At the ROOT prompt do: At the ROOT prompt do:
-<code> +<code cpp
-TGeoManager::Import("geometryOutputGDMLFormat.gdml");+TGeoManager::Import("detector.gdml");
 gGeoManager->GetTopVolume()->Draw("ogl"); gGeoManager->GetTopVolume()->Draw("ogl");
 </code> </code>
-This should popup an OpenGL dispaly with the detector which you can +This should popup an OpenGL display with the detector which you can
-clip, pan, rotate etc.+clip, pan, rotate etc. See this image:
 +{{:fcs:fcchh:image.png?400|}}
 ====== People ====== ====== People ======
fcs/fcchh/intro.txt · Last modified: 2016/09/23 21:45 by asc
