fcs:fcchh:intro [2016/04/02 01:06] asc |
fcs:fcchh:intro [2016/04/02 01:16] asc [FCC-hh detector studies: Software and detectors] |
Line 17: | Line 17: | ||
in the [[http:// | in the [[http:// | ||
Look for **sifcch4.zip** file. This detector corresponds to [[http:// | Look for **sifcch4.zip** file. This detector corresponds to [[http:// | ||
+ | The description of this detector is [[http:// | ||
Line 40: | Line 41: | ||
* Visualisation of reconstructed events using Wired4 display | * Visualisation of reconstructed events using Wired4 display | ||
- | You can find more details in [[http:// | + | You can find more details in [[asc: |
- | All examples for this page are located in the " | + | |
Line 112: | Line 111: | ||
The current version of the FCC-hh detector is located in the [[http:// | The current version of the FCC-hh detector is located in the [[http:// | ||
- | zip file with your detector, say " | + | zip file with your detector, say " |
- | You can study this geometry using the description link. | + | You can study this geometry using the "description" |
- | To visualize this detector, use Wired4. Download the detector.zip, | + | To visualize this detector, use Wired4. Download the "detector.zip" file, unpack and locate the file " |
Line 142: | Line 141: | ||
====== Visualizing geometry using ROOT ====== | ====== Visualizing geometry using ROOT ====== | ||
- | (contribution | + | (contribution |
You can also visualize the detector using ROOT. Here are a few steps: | You can also visualize the detector using ROOT. Here are a few steps: |
