fcs:fcchh:sgun [2016/03/22 13:50] asc [SiFCC3 detector] |
fcs:fcchh:sgun [2016/04/21 05:49] asc [Single particles with the SiFCC detector] |
Line 1: | Line 1: | ||
+ | [[fcs: | ||
====== Single particle studies ====== | ====== Single particle studies ====== | ||
The results shown on this page use [[https:// | The results shown on this page use [[https:// | ||
+ | <hidden Click here to show how to install it> | ||
Line 8: | Line 12: | ||
+ | ===== Single particles with the SiFCC detector ===== | ||
- | ===== SiFCC3 detector ===== | ||
- | + | You can study this the | |
- | You can study this geometry using [[http:// | + | |
We will download samples in directories **dataNgev** using reg. expressions. We will use 2 threads and 100 files (if available) from each sample. | We will download samples in directories **dataNgev** using reg. expressions. We will use 2 threads and 100 files (if available) from each sample. | ||
- | hs-get | + | hs-get pgun_pi_1to10000gev%rfull006 |
+ | Run a Python script given here: {{: | ||
+ | <code bash> | ||
+ | fpad pgun1.py data1gev | ||
+ | fpad pgun1.py data10gev | ||
+ | fpad pgun1.py data100gev | ||
+ | fpad pgun1.py data1000gev | ||
+ | fpad pgun1.py data10000gev | ||
+ | A typical plot for 100 GeV single pion is shown here | ||
+ | <hidden Click to show this image> | ||
+ | Find more single particle samples using the tag [[http:// | ||
+ | Go to " | ||
+ | How to analyze LCIO data using C++ code is discussed in [[fcs: |
