fcs:fcchh:sgun [2016/04/02 01:14] asc [SiFCC3 detector] |
fcs:fcchh:sgun [2016/04/21 05:48] asc [Single particles with the SiFCC detector] |
Line 13: | Line 13: | ||
- | ===== SiFCC3 | + | ===== Single particles with the SiFCC detector ===== |
Line 27: | Line 27: | ||
- | Run a Python script given here: {{: | + | Run a Python script given here: {{: |
Line 41: | Line 41: | ||
+ | Find more single particle samples using the tag [[http:// | ||
+ | Go to " | ||
+ | How to analyze LCIO data using C++ code is dicussed in [[fcs: |
