fcs:fcchh:sgun [2016/04/20 02:29] asc [Single particles with the SiFCC detector] |
fcs:fcchh:sgun [2016/09/25 00:29] asc |
Line 16: | Line 16: | ||
- | You can study this the geometry of FCChh-v4 detector using [[http:// | + | You can study this the geometry of FCChh-v7 detector using [[http:// |
We will download samples in directories **dataNgev** using reg. expressions. We will use 2 threads and 100 files (if available) from each sample. | We will download samples in directories **dataNgev** using reg. expressions. We will use 2 threads and 100 files (if available) from each sample. | ||
- | hs-get pgun_pi_1to10000gev%rfull006 | + | hs-get pgun_pi_1to10000gev%rfull009 |
- | Run a Python script given here: {{: | + | Run a Python script given here: {{: |
Line 42: | Line 42: | ||
- | Find more single particle samples using the tag [[http:// | + | Find more single particle samples using the tag [[http:// |
+ | Go to " | ||
+ | How to analyze LCIO data using C++ code is discussed in [[fcs: |
