fcs:fcchh:zprime [2016/03/23 13:40] asc [SiFCC3 detector] |
fcs:fcchh:zprime [2016/04/27 13:50] asc |
Line 12: | Line 12: | ||
- | ===== SiFCC3 detector ===== | ||
+ | ===== SiFCC detector ===== | ||
- | You can study this the geometry of the FCChh-v3 detector using [[http:// | + | |
+ | You can study this the geometry of the FCChh-v3 detector using [[http:// | ||
Download Z'(10 TeV) to XX final state as: | Download Z'(10 TeV) to XX final state as: | ||
Line 24: | Line 25: | ||
- | An example code which creates jet masses of anti-kT jets (R=0.8) is attached. | + | An example code which creates jet masses of anti-kT jets (R=0.8) is {{: |
- | It fills 3 histograms with jet masses for leading antiKT jets (truth, PFO, Clusters). | + | It fills 3 histograms with jet masses for leading |
- | Run it as | + | Run it as: |
fpad jetmass.py tev10mumu_pythia6_zprime10tev_ww%rfull005 | fpad jetmass.py tev10mumu_pythia6_zprime10tev_ww%rfull005 | ||
The created image is shown below | The created image is shown below | ||
+ | You can write a C++ code which calls the FastJet (with jet substructure variables) using the packages posted to [[fcs: |
