hpc:lcgcmake [2015/08/21 19:41] jchilders [LCGCMake] |
hpc:lcgcmake [2015/08/24 19:25] jchilders [Setup] |
Line 16: | Line 16: | ||
- | === Install Dependencies === | + | ==== Install Dependencies |
Line 119: | Line 119: | ||
-DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} | -DCMAKE_C_COMPILER=${CMAKE_C_COMPILER} | ||
-DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</ | -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</ | ||
+ | * Edit '' | ||
+ | -DCMAKE_CXX_COMPILER=${CMAKE_CXX_COMPILER}</ | ||
* Edit '' | * Edit '' | ||
+ | * Edit '' | ||
+ | set(hepmc3_source_command GIT_REPOSITORY http:// | ||
=== Building LCG === | === Building LCG === | ||
Line 128: | Line 133: | ||
When a build fails, look at this list for fixes, fix, then continue with '' | When a build fails, look at this list for fixes, fix, then continue with '' | ||
* After the '' | * After the '' | ||
* After ROOT 6 downloads and fails the build, you can make the following edits to fix the ODBC files. Add to the files '' | * After ROOT 6 downloads and fails the build, you can make the following edits to fix the ODBC files. Add to the files '' | ||
