Both sides previous revision Previous revision | |||
hpc:lcgcmake [2015/08/24 19:25] jchilders [Setup] |
hpc:lcgcmake [2015/08/24 19:29] jchilders |
Line 59: | Line 59: | ||
=== Before you build === | === Before you build === | ||
+ | * The bits below are summarized in this patch file [[hpc: | ||
* Edit '' | * Edit '' | ||
* You have to force cmake to identify your machine as slc6 because some of the tarballs live on a webserver with '' | * You have to force cmake to identify your machine as slc6 because some of the tarballs live on a webserver with '' |
