User Tools
Site Tools
hpc:rabbitmq
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
hpc:rabbitmq [2014/03/18 13:44]
jchilders
hpc:rabbitmq [2014/03/18 13:48]
jchilders
Line 12: Line 12:
   {rabbit, [   {rabbit, [
      {ssl_listeners, [5671]},      {ssl_listeners, [5671]},
-     {ssl_options, [{cacertfile,"/Users/childers/workarea/rabbitmq/testca/cacert.pem"}, +     {ssl_options, [{cacertfile,"/path/to/testca/cacert.pem"},
-                    {certfile,"/Users/childers/workarea/rabbitmq/server/cert.pem"}, +                    {certfile,"/path/to/server/cert.pem"},
-                    {keyfile,"/Users/childers/workarea/rabbitmq/server/key.pem"},+                    {keyfile,"/path/to/server/key.pem"},
                     {verify,verify_peer},                     {verify,verify_peer},
                     {fail_if_no_peer_cert,true}]}                     {fail_if_no_peer_cert,true}]}
-</code python>+</code>
 +   * Added this code to the RabbitMQ Client (via Pika) Setup:
 +<code python
 +#!/usr/bin/env python
 +import pika
 +import sys,ssl
 +# Setup our ssl options
 +ssl_options = {"ca_certs": "/path/to/testca/cacert.pem",
 +               "certfile": "/path/to/client/cert.pem",
 +               "keyfile": "/path/to/client/key.pem",
 +               "cert_reqs": ssl.CERT_REQUIRED,
 +connection = pika.BlockingConnection(pika.ConnectionParameters(host='servername.com',port=5671,ssl=True,ssl_options=ssl_options))
 +channel = connection.channel()
 +channel.queue_declare(queue='hello'
 +channel.basic_publish(exchange='',
 +                      routing_key='hello',
 +                      body='Hello World!'
 +print " [x] Sent 'Hello World!'"
 +connection.close()
 +</code>
hpc/rabbitmq.txt · Last modified: 2016/06/24 16:28 by jchilders
