User Tools
Site Tools
itk:using_the_pixel_application
Using the Pixel Application
Become superuser with the 'su' command.
cd ~/daq/rce
source ./scripts/setup-gen3.sh
calibGui
You can ssh into the HSIO-2 to run calibserver. This is not necessary unless you want to see real-time outputs from the server.
ssh [email protected]
export PATH=/root/pixelrce/bin:$PATH; export LD_LIBRARY_PATH=/root/pixelrce/lib:$LD_LIBRARY_PATH
calibserver
To compile and upload changes to the pixel application:
cd ~/daq/rce/build.slc6-rcf; make
cd ~/daq/rce/build.arm-rcf; make
cd ~/daq/rce/
rsync -e 'ssh -l root' -rlptDv /sw/atlas/sw/lcg/LCG_81b/Boost/1.59.0_python2.7/armv7l-archlinux-gcc52-opt/lib 192.168.3.3:/root/pixelrce/
rsync -rlptDv -e 'ssh -l root' build.arm-rcf/{bin,lib} 192.168.3.3:/root/pixelrce\
Use Inlink X, Outlink X, where the module is plugged into port AX. Use Rce 0.
itk/using_the_pixel_application.txt · Last modified: 2016/09/09 16:50 by mazhang
