snowmass2013:analyse_d3 [2013/06/01 02:47] asc |
snowmass2013:analyse_d3 [2013/06/01 03:02] asc |
Line 1: | Line 1: | ||
[[snowmass2013: | [[snowmass2013: | ||
- | === How to analyze in C++ === | + | ==== How to analyze in C++ ==== |
- | This example shows how to run a program over all files in a certain directory, fill histograms (pT and jet mass) and | + | This example shows how to run a C+= program over all Delphes ROOT files located |
- | save histograms | + | |
Look at the workbook of Delphes3 [[https:// | Look at the workbook of Delphes3 [[https:// | ||
Line 17: | Line 16: | ||
- | === Advanced | + | ==== Advanced |
This assumes that Delphes3 is already installed. You have the directory " | This assumes that Delphes3 is already installed. You have the directory " | ||
Line 23: | Line 22: | ||
Get the analysis file: {{: | Get the analysis file: {{: | ||
tar -zvxf antup.tgz | tar -zvxf antup.tgz | ||
cd antup | cd antup | ||
Line 29: | Line 28: | ||
So you will see 2 directories: | So you will see 2 directories: | ||
delphes3 | delphes3 | ||
antup | antup | ||
Line 37: | Line 36: | ||
Now go to the directory " | Now go to the directory " | ||
ln -s ../ | ln -s ../ | ||
Line 43: | Line 42: | ||
In my case, it will look as: | In my case, it will look as: | ||
analysis.h | analysis.h | ||
A_RUN_TEST | A_RUN_TEST | ||
Line 55: | Line 54: | ||
Check that you see the shared Delphes3 file | Check that you see the shared Delphes3 file | ||
ls -l delphes/*so | ls -l delphes/*so | ||
Line 67: | Line 66: | ||
But before you do this, you will need to set " | But before you do this, you will need to set " | ||
- | === How to analyze in PyROOT === | + | ==== How to analyze in PyROOT |
- | If ROOT was compiled using " | + | If ROOT was compiled using " |
- | + | [[https:// | |
- | <code python> | + | |
+ | <code python test.py> | ||
# Based on P.Onyisi example | # Based on P.Onyisi example | ||
Line 87: | Line 86: | ||
t=f.Delphes # extract the tree | t=f.Delphes # extract the tree | ||
h=TH1D(' | h=TH1D(' | ||
- | c=TCanvas() # build a canvas | + | c1=TCanvas() # build a canvas |
n=0 | n=0 | ||
Line 99: | Line 98: | ||
if (raw_input(" | if (raw_input(" | ||
c1.Close(); sys.exit(1); | c1.Close(); sys.exit(1); | ||
+ | Run this code as: | ||
+ | python test.py file.root | ||
+ | You will see this image: | ||
+ | ====How to analyze in Java==== | ||
+ | MC truth information and most of ROOT files with Delphes outputs | ||
+ | are stored in the PROMC file format which can be analyzed on any platform. | ||
+ | Read this [[snowmass2013: | ||
