User Tools
Site Tools
snowmass2013:montecarlo_d3zprime3000
<<back
Zprime(3000) to ttbar
Here are samples of Delphes 3.05 events generated for the 14 TeV center-of-mass energy (pp collisions). The events are generated for 0 pileup, 50 and 140 pileup scenarios.
All data are stored in the ROOT format using the standard Delphes 3.05 output. Therefore, it is recommended to install Delphes 3.0.5 and look at the example explaining how to read such ROOT files (see the directory “Examples” inside the Delphes package).
The samples use the ATLAS detector geometry located in “examples/delphes_card_ATLAS.tcl” of the Delphes 3.05 installation. We use “towers” to build antiKT4 jets.
The truth information from the signal MC shown above was used to overlay with 50 pile up events (fixed number, not “Poisson” case!) The events were overplayed at the HEPMC true level (thanks to Andy Buckley for his help and http://pilemc.hepforge.org/ tool), and then were processed using Delphes 3.05.
How to download
Please read the Section How to download
How files are generated
In total, there are 200 Zprime (mass=3000 GeV) events per one file.
Look at the log files of PYTHIA8 and Delphes for this runs:
Log files
Zprime(3000) to ttbar without pileups
Get the Delphes3 ROOT files from this download link
In total, there are 96 files, with 200 ttbar events in each. Thus the total number of events is 19200 signal events.
Here is an example for downloading 5 files:
python download.py 5  delphes3/pythia_zprime3000/signal  pythia8_zprime3000_ttbar
(set 5 to 96 to download all)
Zprime(3000) to ttbar with mu=50
python download.py 5  delphes3/pythia_zprime3000/mu50  pythia8_zprime3000_ttbar_mu50
Zprime(3000) to ttbar with mu=140
python download.py 5  delphes3/pythia_zprime3000/mu140  pythia8_zprime3000_ttbar_mu140
Info about true particle record
To reduce ROOT file size, truth information in these ROOT files was slimmed. Please read here.
How to analyze
If you need to find the effect of pileup on top reconstruction or a jet measurement, you need to run the analysis code over signal MC and then over the signal+pileup MC files. Read analyse_d3
Sergei Chekanov 2013/03/06 20:48
snowmass2013/montecarlo_d3zprime3000.txt · Last modified: 2014/04/24 01:51 (external edit)
