tdq:ftk [2016/04/15 12:32] rwang |
tdq:ftk [2016/07/28 15:18] rwang [FLIC-FTK Level-2 Interface Card] |
Line 12: | Line 12: | ||
mesh ATCA backplane. | mesh ATCA backplane. | ||
- | FLIC specification {{: | + | FLIC specification {{: |
FLIC register map{{: | FLIC register map{{: | ||
=====FLIC production boards===== | =====FLIC production boards===== | ||
=====FLIC hardware design===== | =====FLIC hardware design===== | ||
* 18-layer circuit board, standard FR-4 | * 18-layer circuit board, standard FR-4 | ||
Line 28: | Line 27: | ||
- Each has 8 SERDES links of input from I/O processor FPGAs, matched to total ATCA output bandwidth | - Each has 8 SERDES links of input from I/O processor FPGAs, matched to total ATCA output bandwidth | ||
- Distribute data, from the FLIC to the multiple processor blades | - Distribute data, from the FLIC to the multiple processor blades | ||
* Full, matched-bandwidth internal mesh of SERDES links between all FPGAs | * Full, matched-bandwidth internal mesh of SERDES links between all FPGAs | ||
Line 45: | Line 43: | ||
==SSBe== | ==SSBe== | ||
- | =====Processor Blade===== | + | =====Spy buffer===== |
+ | The FLIC spy buffer copy the tagged events from U1&U2 to U3&U4 then assembly them into ethernet package and send to ATCA processor blade via 40Gbps ATCA back plane. | ||
+ | ====Processor Blade==== | ||
The manual for the adlink processor blade 6150 at ANL{{: | The manual for the adlink processor blade 6150 at ANL{{: | ||
The manual for the adlink processor blade 6155 at CERN{{: | The manual for the adlink processor blade 6155 at CERN{{: | ||
+ | =====ATCA shelf===== | ||
+ | IPMB address for the slots | ||
+ | |Slot | IPMB address| | ||
+ | |1 | 82 | | ||
+ | |2 | 84 | | ||
+ | |3 | 86 | | ||
+ | |4 | 88 | | ||
+ | |5 | 8a | | ||
+ | |6 | 8c | | ||
+ | ====Shelf Manager==== | ||
+ | ===Power control=== | ||
+ | To turn on and off boards, follow the procedure in this link: | ||
+ | https:// | ||
+ | ===IPMC=== | ||
+ | Talk to the IPMC. | ||
+ | eg. get the device ID of the board in slot 3: | ||
+ | clia sendcmd (IPMB address) (netfn) (command) | ||
+ | clia sendcmd 86 | ||
+ | get Device SDR Info: | ||
+ | More detailed IPMI command can be found here: | ||
+ | https:// |
