tdq:ftk [2016/04/15 16:10] rwang [Processor Blade] |
tdq:ftk [2016/07/28 15:18] rwang [FLIC-FTK Level-2 Interface Card] |
Line 12: | Line 12: | ||
mesh ATCA backplane. | mesh ATCA backplane. | ||
- | FLIC specification {{: | + | FLIC specification {{: |
FLIC register map{{: | FLIC register map{{: | ||
=====FLIC production boards===== | =====FLIC production boards===== | ||
Line 28: | Line 27: | ||
- Each has 8 SERDES links of input from I/O processor FPGAs, matched to total ATCA output bandwidth | - Each has 8 SERDES links of input from I/O processor FPGAs, matched to total ATCA output bandwidth | ||
- Distribute data, from the FLIC to the multiple processor blades | - Distribute data, from the FLIC to the multiple processor blades | ||
* Full, matched-bandwidth internal mesh of SERDES links between all FPGAs | * Full, matched-bandwidth internal mesh of SERDES links between all FPGAs | ||
Line 45: | Line 43: | ||
==SSBe== | ==SSBe== | ||
- | =====Processor Blade===== | + | =====Spy buffer===== |
+ | The FLIC spy buffer copy the tagged events from U1&U2 to U3&U4 then assembly them into ethernet package and send to ATCA processor blade via 40Gbps ATCA back plane. | ||
+ | ====Processor Blade==== | ||
The manual for the adlink processor blade 6150 at ANL{{: | The manual for the adlink processor blade 6150 at ANL{{: | ||
Line 62: | Line 66: | ||
====Shelf Manager==== | ====Shelf Manager==== | ||
+ | ===Power control=== | ||
+ | To turn on and off boards, follow the procedure in this link: | ||
+ | https:// | ||
===IPMC=== | ===IPMC=== | ||
Talk to the IPMC. | Talk to the IPMC. |
