User Tools
Site Tools
tilecal:lvpstripmonitoring
Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
tilecal:lvpstripmonitoring [2015/05/02 16:50]
duong
tilecal:lvpstripmonitoring [2018/05/30 18:11]
asc
Line 1: Line 1:
 +====== LVPS Trip monitoring in 2018 ======
 +<note>All manual interventions were taken from [[https://atlasop.cern.ch/elisa/display | Operation elog]] </note>
 +====== LVPS Trip monitoring in 2017 ======
 +====== LVPS Trip monitoring in 2016 ======
 ====== LVPS Trip monitoring in 2015 ====== ====== LVPS Trip monitoring in 2015 ======
 +Current trip status is given on  [[https://atlaswww.hep.anl.gov/asc/TileCal/EventReporterLVPS/| trip monitoring chart]]. All manual interventions are removed based on the table shown below.
 | Module | Trip time | Symptom, problem found | DCS image | | Module | Trip time | Symptom, problem found | DCS image |
-| EBC62  | 2015-04-22 11:18:28 | NOT a real trip, EBC62 was power-cycled requested by DCS to fix timing jump (power-cycled https://atlasop.cern.ch/elisa/display/258617 ; timing jump https://atlasop.cern.ch/elisa/display/258618) |  +|EBC10| 2015.07.05 06:19.16 | trip? https://atlasop.cern.ch/elisa/display/267540|
-| EBC26 | 2015-04-04 15:10:21| REAL trip https://atlasop.cern.ch/elisa/display/256790|+|EBC22|2015-06-12 10:36:28|NOT a real trip. Automatic Power Cycle on EBC22, asked by DAQ System https://atlasop.cern.ch/elisa/display/264611|
 +|LBA43|2015-05-12 16:54:12|NOT a real trip. Intervention was necessary to reboot the server which handles the ELMB monitoring - the detector was all the time ON (Filipe e-mail)|
 +|LBA47|2015-04-29 09:56:12|NOT a real trip. Did TileMB test which turned off and then turned on the module https://atlasop.cern.ch/elisa/display/259446|
 +|LBA37|2015-04-28 13:33:51|NOT a real trip. Power-cycled to verify deskew adjustment https://atlasop.cern.ch/elisa/display/259331|
 +|LBC12|2015-04-28 13:31:01|NOT a real trip. Power-cycled to verify deskew adjustment https://atlasop.cern.ch/elisa/display/259331|
 +|LBA07|2015-04-28 13:30:11|NOT a real trip. Power-cycled to verify deskew adjustment https://atlasop.cern.ch/elisa/display/259331|
 +|EBA19|2015-04-28 13:22:03|NOT a real trip. Power-cycled to verify deskew adjustment https://atlasop.cern.ch/elisa/display/259331|
 +|LBC24|2015-04-28 13:16:51|NOT a real trip. Power-cycled to verify deskew adjustment https://atlasop.cern.ch/elisa/display/259331|
 +|EBC62| 2015-04-22 11:18:28 | NOT a real trip, EBC62 was power-cycled requested by DCS to fix timing jump (power-cycled https://atlasop.cern.ch/elisa/display/258617 ; timing jump https://atlasop.cern.ch/elisa/display/258618) |
 +|LBC18|2015-04-22 11:19:31|NOT a real trip. Power-cycled https://atlasop.cern.ch/elisa/display/258618|
 +|EBA08|2015-04-17 22:47:27|Not a real trip, HV_830 tripped, restarted HV side https://atlasop.cern.ch/elisa/display/258168|
 +|EBA02|2015-04-16 15:19:54|NOT a real trip, power-cycled to fix discarding events https://atlasop.cern.ch/elisa/display/257996|
 +|<fc #FF0000>EBC26</fc>| 2015-04-04 15:10:21| REAL trip https://atlasop.cern.ch/elisa/display/256790
 +|LBC03| 2015-04-09 06:07:10 | NOT a real trip, power cycles requested by DAQ FSM |
 |LBC31| 2015-04-03 10:01:31 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off at ~0:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256633 and was switched on again ~13:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256669. The problem was fixed by using 2nd readout fiber https://atlasop.cern.ch/elisa/display/256668 |  |LBC31| 2015-04-03 10:01:31 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off at ~0:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256633 and was switched on again ~13:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256669. The problem was fixed by using 2nd readout fiber https://atlasop.cern.ch/elisa/display/256668 |
 |LBC31| 2015-04-03 02:00:00 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off on ~0:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256633 and was switched on again ~13:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256669. The problem was fixed by using 2nd readout fiber https://atlasop.cern.ch/elisa/display/256668 | |LBC31| 2015-04-03 02:00:00 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off on ~0:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256633 and was switched on again ~13:00 on April 3, 2015 https://atlasop.cern.ch/elisa/display/256669. The problem was fixed by using 2nd readout fiber https://atlasop.cern.ch/elisa/display/256668 |
 |LBC31| 2015-04-02 21:01:49 | NOT a real trip, power-cycled to fix 100% discarding events https://atlasop.cern.ch/elisa/display/256626. It was switched off ~0:00 on April 03, 2015 https://atlasop.cern.ch/elisa/display/256633| |LBC31| 2015-04-02 21:01:49 | NOT a real trip, power-cycled to fix 100% discarding events https://atlasop.cern.ch/elisa/display/256626. It was switched off ~0:00 on April 03, 2015 https://atlasop.cern.ch/elisa/display/256633|
-|LBC31| 12:18:09 | Not sure it is real trip, but LBC31 experienced multiple auto power cycle during 2014-04-02 until it turned off https://atlasop.cern.ch/elisa/display/256633 | +|LBC31|2015-04-02 12:18:09| NOT a real trip, LBC31 experienced multiple auto power cycle during 2014-04-02 until it turned off https://atlasop.cern.ch/elisa/display/256633 |
 | LBC31  | 2015-04-02 00:59:29 | NOT a real trip, power-cycled to fix 99% discarding events https://atlasop.cern.ch/elisa/display/256502 | | LBC31  | 2015-04-02 00:59:29 | NOT a real trip, power-cycled to fix 99% discarding events https://atlasop.cern.ch/elisa/display/256502 |
-| EBA11 | 2015-03-31 23:35:39 |Power cycled https://atlasop.cern.ch/elisa/display/256382 | | +| EBA11 | 2015-03-31 23:35:39 |NOT a real trip, power cycled https://atlasop.cern.ch/elisa/display/256382 | |
-| LBC11 | 2015-03-31 10:22:27 |Seem to be power cycled after this "LBC11 seems to be off (at least the ROD link is off). [Run #259427 LB #51]" https://atlasop.cern.ch/elisa/display/256329two day later report showed it was power recycled frequently https://atlasop.cern.ch/elisa/display/256504| | +| LBC11 | 2015-03-31 10:22:27 |NOT a real trip, power cycles requested by DAQ FSM| |
-| EBC10 | 2015-03-25 11:57:07 |real trip https://atlasop.cern.ch/elisa/display/255607 | | +<fc #FF0000>EBC10</fc> | 2015-03-25 11:57:07 |REAL trip https://atlasop.cern.ch/elisa/display/255607 | |
-| EBC25 | 2015-03-25 01:45:56 |Power cycled due to lost CAN-bus communication https://atlasop.cern.ch/elisa/display/255559| | +| EBC25 | 2015-03-25 01:45:56 |NOT a real trip. Power-cycled due to lost CAN-bus communication https://atlasop.cern.ch/elisa/display/255559| |
-| EBC26 | 2015-03-19 08:08:17 |Real trip https://atlasop.cern.ch/elisa/display/254713 | | +<fc #FF0000>EBC26</fc> | 2015-03-19 08:08:17 |REAL trip https://atlasop.cern.ch/elisa/display/254713 | |
-| EBC10 | 2015-03-13 23:18:49 | real trip https://atlasop.cern.ch/elisa/display/254196 | | +<fc #FF0000>EBC10</fc> | 2015-03-13 23:18:49 |REAL trip https://atlasop.cern.ch/elisa/display/254196 | |
-| LBC20 | 2015-03-11 10:14:45 | | | +| LBC20 | 2015-03-11 10:14:45 |NOT a real trip. HV_Micro reset ( by LVforHV PWR cycle) to fix HV on PMT42 https://atlasop.cern.ch/elisa/display/253653 | |
-| EBC56 | 2015-03-10 13:23:45 | | | +| EBC56 | 2015-03-10 13:23:45 |NOT a real trip. EBC56 was power cycled due to "No communication" with HV-Micro inside drawer (issue also reported by the OPCUA server) https://atlasop.cern.ch/elisa/display/253516 | |
-| LBA47 | 2015-03-09 16:00:02 | | | +| LBA47 | 2015-03-09 16:00:02 |NOT a real trip. Performed several tests for debugging the synchronization problem. The module was switched on and off during test. https://atlasop.cern.ch/elisa/display/253373| |
-| LBA05 | 2015-03-06 12:56:09 |Not found elog for this trip but later on 3/15 this modules discarded events (67%) and was power recycled by that (https://atlasop.cern.ch/elisa/display/254185). It could be that this trip was because of power-cycled by the same reason | |+| LBA05 | 2015-03-06 12:56:09 |NOT a real trip. Performed MinBias test and module was power-cycled https://atlasop.cern.ch/elisa/display/252976| |
tilecal/lvpstripmonitoring.txt · Last modified: 2022/01/31 13:59 by asc
