tilecal:lvpstripmonitoring [2015/05/02 17:52] duong |
tilecal:lvpstripmonitoring [2018/05/30 18:11] asc |
Line 1: | Line 1: | ||
+ | ====== LVPS Trip monitoring in 2018 ====== | ||
+ | ====== LVPS Trip monitoring in 2017 ====== | ||
+ | ====== LVPS Trip monitoring in 2016 ====== | ||
====== LVPS Trip monitoring in 2015 ====== | ====== LVPS Trip monitoring in 2015 ====== | ||
+ | Current trip status is given on [[https:// | ||
| Module | Trip time | Symptom, problem found | DCS image | | | Module | Trip time | Symptom, problem found | DCS image | | ||
+ | |EBC10| 2015.07.05 06:19.16 | trip? https:// | ||
+ | |EBC22|2015-06-12 10: | ||
+ | |LBA43|2015-05-12 16: | ||
|LBA47|2015-04-29 09: | |LBA47|2015-04-29 09: | ||
|LBA37|2015-04-28 13: | |LBA37|2015-04-28 13: | ||
Line 15: | Line 28: | ||
|EBA02|2015-04-16 15: | |EBA02|2015-04-16 15: | ||
|<fc # | |<fc # | ||
- | |LBC03| 2015-04-09 06:07:10 | Probably | + | |LBC03| 2015-04-09 06:07:10 | NOT a real trip, power cycles requested by DAQ FSM | |
|LBC31| 2015-04-03 10:01:31 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off at ~0:00 on April 3, 2015 https:// | |LBC31| 2015-04-03 10:01:31 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off at ~0:00 on April 3, 2015 https:// | ||
|LBC31| 2015-04-03 02:00:00 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off on ~0:00 on April 3, 2015 https:// | |LBC31| 2015-04-03 02:00:00 | NOT a real trip, the module was due to discarding events and auto power-cycled many time. It was off on ~0:00 on April 3, 2015 https:// | ||
|LBC31| 2015-04-02 21:01:49 | NOT a real trip, power-cycled to fix 100% discarding events https:// | |LBC31| 2015-04-02 21:01:49 | NOT a real trip, power-cycled to fix 100% discarding events https:// | ||
- | |LBC31|2015-04-02 12: | + | |LBC31|2015-04-02 12: |
| LBC31 | 2015-04-02 00:59:29 | NOT a real trip, power-cycled to fix 99% discarding events https:// | | LBC31 | 2015-04-02 00:59:29 | NOT a real trip, power-cycled to fix 99% discarding events https:// | ||
- | | EBA11 | 2015-03-31 23:35:39 |Power cycled https:// | + | | EBA11 | 2015-03-31 23:35:39 |NOT a real trip, power cycled https:// |
- | | LBC11 | 2015-03-31 10:22:27 |Seem to be power cycled after this "LBC11 seems to be off (at least the ROD link is off). [Run #259427 LB #51]" https:// | + | | LBC11 | 2015-03-31 10:22:27 |NOT a real trip, power cycles requested by DAQ FSM| | |
- | | EBC10 | 2015-03-25 11:57:07 |real trip https:// | + | | <fc #FF0000>EBC10</ |
- | | EBC25 | 2015-03-25 01: | + | | EBC25 | 2015-03-25 01:45:56 |NOT a real trip. Power-cycled due to lost CAN-bus communication https:// |
- | | EBC26 | 2015-03-19 08:08:17 |Real trip https:// | + | | <fc #FF0000>EBC26</ |
- | | EBC10 | 2015-03-13 23:18:49 | real trip https:// | + | | <fc #FF0000>EBC10</ |
| LBC20 | 2015-03-11 10:14:45 |NOT a real trip. HV_Micro reset ( by LVforHV PWR cycle) to fix HV on PMT42 https:// | | LBC20 | 2015-03-11 10:14:45 |NOT a real trip. HV_Micro reset ( by LVforHV PWR cycle) to fix HV on PMT42 https:// | ||
| EBC56 | 2015-03-10 13:23:45 |NOT a real trip. EBC56 was power cycled due to "No communication" | | EBC56 | 2015-03-10 13:23:45 |NOT a real trip. EBC56 was power cycled due to "No communication" |
