tilecal:maintenance [2018/08/08 16:40] asc [Setting up MobiDick computers] |
tilecal:maintenance [2021/01/14 21:24] asc |
Line 6: | Line 6: | ||
http:// | http:// | ||
+ | Description: | ||
+ | Mobidick note {{: | ||
+ | GIT repository: https:// | ||
====== Setting up MobiDick computers ====== | ====== Setting up MobiDick computers ====== | ||
Line 12: | Line 17: | ||
https:// | https:// | ||
+ | Software link: | ||
+ | https:// | ||
Computer1: mobi1 (user/pass) | Computer1: mobi1 (user/pass) | ||
+ | HP ProBook 450 G5. CSI 0356567 | ||
+ | Install from USB CDROM: F10, the go to boot, then go to " | ||
+ | Mobidick server parameters: | ||
+ | 1570 (port) | ||
+ | xterm -hold -e " | ||
+ | Should install: xterm, telnet, expect | ||
+ | The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server | ||
+ | ===== Differences between software new vs old (working) version ===== | ||
+ | ===== DigNoise panel is different. ===== | ||
+ | Willy version 2.9 2013-02-20 | ||
+ | Mobidick version 5.7 | ||
+ | David Calvet | ||
+ | Working | ||
+ | New version | ||
+ | ===== DigLinerarity ===== | ||
+ | This panel is missing in the working version | ||
+ | ===== DigNoiseHV ===== | ||
+ | Working version has only 52 buttons with " | ||
+ | New version has High Gain test results, "Low Gain results" | ||
