tilecal:maintenance [2018/11/16 10:08] asc |
tilecal:maintenance [2021/01/14 21:24] asc |
Line 9: | Line 9: | ||
Mobidick note {{: | Mobidick note {{: | ||
+ | GIT repository: https:// | ||
====== Setting up MobiDick computers ====== | ====== Setting up MobiDick computers ====== | ||
Line 39: | Line 41: | ||
The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server | The IP 192.168.0.100 should be assigned to laptop automatically via DHCP server | ||
+ | ===== Differences between software new vs old (working) version ===== | ||
+ | ===== DigNoise panel is different. ===== | ||
+ | Willy version 2.9 2013-02-20 | ||
+ | Mobidick version 5.7 | ||
+ | David Calvet | ||
+ | Working | ||
+ | New version | ||
+ | ===== DigLinerarity ===== | ||
+ | This panel is missing in the working version | ||
+ | ===== DigNoiseHV ===== | ||
+ | Working version has only 52 buttons with " | ||
+ | New version has High Gain test results, "Low Gain results" | ||
