User Tools
Site Tools
vlhc:hcal
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
vlhc:hcal [2014/12/02 17:19]
asc [How to run]
vlhc:hcal [2015/01/16 15:53]
asc
Line 1: Line 1:
-====== FCC HCAL using a fast simulation ======+====== Calorimeter studies using a fast simulation ======
 [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim]] repository provides a number of truth-level MC samples for signal and background that can be used as inputs for a fast simulation. The analysis can be done as explained in  [[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=community:refhepsim |this manual]].  [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim]] repository provides a number of truth-level MC samples for signal and background that can be used as inputs for a fast simulation. The analysis can be done as explained in  [[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=community:refhepsim |this manual]].
-Follow these steps:+To simplify the setup, we have prepared a package that includes [[https://cp3.irmp.ucl.ac.be/projects/delphes | Delphes]], [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC]] and HS-TOOLs. Follow these steps:
 <code bash> <code bash>
Line 25: Line 25:
 </code> </code>
-This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied.+This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. They are explained in the sections below.
 ===== ATLAS-like geometry ===== ===== ATLAS-like geometry =====
Line 151: Line 151:
 ===== How to run ===== ===== How to run =====
-We need to bring truth-level data from [[http://atlaswww.hep.anl.gov/hepsim/| HepSim]] and put them somewhere. For this example, +We need to bring truth-level data from [[http://atlaswww.hep.anl.gov/hepsim/| HepSim]] and put them somewhere.
-we will use [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=57 | TTBar sample]] generated with pT>2.5 TeV and look at the jet mass.+We will use [[https://atlaswww.hep.anl.gov/hepsim/info.php?item=57 | TTBar sample]] generated with pT>2.5 TeV and look at the jet mass.
 Go to "analysis" directory and copy a few truth-level files: Go to "analysis" directory and copy a few truth-level files:
 hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_pt2500_mg5  data 2 10 hs-get http://mc.hep.anl.gov/asc/hepsim/events/pp/100tev/ttbar_pt2500_mg5  data 2 10
 </code> </code>
-This copies 10 files in 2 threads and put them to the directory "data". Now we are ready to run over these files.+This copies 10 files in 2 threads and put them to the directory "data". Now we are ready to run over these 10 files.
 Let us make 2 runs: One run  will use the first geometry layout, and the second run will use the 2nd input card. Let us make 2 runs: One run  will use the first geometry layout, and the second run will use the 2nd input card.
Line 178: Line 178:
 {{:vlhc:mass_towers.eps.png?400|}} {{:vlhc:mass_towers.eps.png?400|}}
-{{:vlhc:mass_eflow.eps.png?400|}}
-{{:vlhc:tau32_eflow.eps.png?400|}}
 Note: the eflow option has much better resolution for jet masses. Note: the eflow option has much better resolution for jet masses.
-===== Using particle flows =====+===== Using particle flows (eFlow) =====
Line 200: Line 197:
 +Now let's try to run using "eFlow" cards:
 +{{:vlhc:mass_eflow.eps.png?400|}}
 +{{:vlhc:tau32_eflow.eps.png?400|}}
 ===== Next steps ===== ===== Next steps =====
vlhc/hcal.txt · Last modified: 2015/10/17 15:33 by asc
