vlhc:hcal [2014/12/03 15:37] asc [How to run] |
vlhc:hcal [2014/12/03 15:42] asc [FCC HCAL using a fast simulation] |
Line 3: | Line 3: | ||
[[http:// | [[http:// | ||
- | Follow these steps: | + | To simplify the setup, we have prepared a package that includes [[https:// |
Line 25: | Line 25: | ||
- | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. | + | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. They are explained in the sections below. |
===== ATLAS-like geometry ===== | ===== ATLAS-like geometry ===== | ||
Line 178: | Line 178: | ||
Note: the eflow option has much better resolution for jet masses. | Note: the eflow option has much better resolution for jet masses. | ||
- | ===== Using particle flows ===== | + | ===== Using particle flows (eFlow) |
Line 200: | Line 197: | ||
+ | Now let's try to run using " | ||
===== Next steps ===== | ===== Next steps ===== |
