User Tools
Site Tools
vlhc:hcal
Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
vlhc:hcal [2014/12/03 15:41]
asc
vlhc:hcal [2014/12/03 15:42]
asc [FCC HCAL using a fast simulation]
Line 3: Line 3:
 [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim]] repository provides a number of truth-level MC samples for signal and background that can be used as inputs for a fast simulation. The analysis can be done as explained in  [[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=community:refhepsim |this manual]].  [[http://atlaswww.hep.anl.gov/hepsim/ | HepSim]] repository provides a number of truth-level MC samples for signal and background that can be used as inputs for a fast simulation. The analysis can be done as explained in  [[https://atlaswww.hep.anl.gov/asc/wikidoc/doku.php?id=community:refhepsim |this manual]].
-To simplify the setup, we have prepared a package that includes [[http://cp3.irmp.ucl.ac.be/ | Delphes-3.1.2]], [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC 1.5]] and HS-TOOLs. +To simplify the setup, we have prepared a package that includes [[https://cp3.irmp.ucl.ac.be/projects/delphes | Delphes]], [[http://atlaswww.hep.anl.gov/asc/promc/ | ProMC]] and HS-TOOLs. Follow these steps:
-Follow these steps:+
 <code bash> <code bash>
Line 27: Line 25:
 </code> </code>
-This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied.+This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. They are explained in the sections below.
 ===== ATLAS-like geometry ===== ===== ATLAS-like geometry =====
vlhc/hcal.txt · Last modified: 2015/10/17 15:33 by asc
