vlhc:hcal [2014/11/21 17:36] asc [HCAL studies using a fast simulation] |
vlhc:hcal [2015/10/17 15:33] (current) asc |
Line 1: | Line 1: | ||
- | Use [[http:// | + | [[http:// |
- | Follow these steps: | + | To simplify the setup, we have prepared a package that includes [[https:// |
- | wget http:// | + | wget http:// |
tar -zvxf FastHepSim.tgz | tar -zvxf FastHepSim.tgz | ||
cd FastHepSim/ | cd FastHepSim/ | ||
Line 25: | Line 25: | ||
- | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. | + | This compiles the analysis program (analysis.cc) that fills pT and jet mass histograms. Before running this program, we will describe what detector geometry can be studied. They are explained in the sections below. |
===== ATLAS-like geometry ===== | ===== ATLAS-like geometry ===== | ||
Line 34: | Line 34: | ||
- | Creates jets from " | + | Creates jets from " |
For the initial test, we assume the following segmentation: | For the initial test, we assume the following segmentation: | ||
Line 40: | Line 40: | ||
* HCAL has 64 modules in Phi and Eta=0.1 in the central region | * HCAL has 64 modules in Phi and Eta=0.1 in the central region | ||
* ECAL has x4 better segmentation | * ECAL has x4 better segmentation | ||
+ | * 60% of energy of charged pions and all baryons are in HCAL | ||
This HCAL geometry has a well balanced segmentation in 2D (same angle of 5.625 deg in Phi and Theta). | This HCAL geometry has a well balanced segmentation in 2D (same angle of 5.625 deg in Phi and Theta). | ||
Line 56: | Line 57: | ||
- | Electrons and photons (pi0!) do not leak to HCAL. 40% of charged pions and all baryons deposit their energy in HCAL. | + | Electrons and photons (pi0!) do not leak to HCAL. |
Line 150: | Line 151: | ||
===== How to run ===== | ===== How to run ===== | ||
- | We need to bring truth-level data from [[http:// | + | We need to bring truth-level data from [[http:// |
- | we will use [[https:// | + | We will use [[https:// |
Go to " | Go to " | ||
hs-get http:// | hs-get http:// | ||
- | This copies 10 files in 2 threads and put them to the directory " | + | This copies 10 files in 2 threads and put them to the directory " |
Let us make 2 runs: One run will use the first geometry layout, and the second run will use the 2nd input card. | Let us make 2 runs: One run will use the first geometry layout, and the second run will use the 2nd input card. | ||
Line 173: | Line 174: | ||
To make plot, run {{: | To make plot, run {{: | ||
Note: the eflow option has much better resolution for jet masses. | Note: the eflow option has much better resolution for jet masses. | ||
- | ===== Using particle flows ===== | + | ===== Using particle flows (eFlow) |
Line 193: | Line 197: | ||
+ | Now let's try to run using " | ||
===== Next steps ===== | ===== Next steps ===== |
