User Tools
Site Tools
fcs:cepc:2017
Differences
fcs:cepc:2017 [2024/07/01 21:25] (current) – created - external edit 127.0.0.1
Line 1: Line 1:
 +===== CEPC tracking studies =====
 +This wiki describe track resolution studies using 2 designs with different outer tracker radius.
 +The plots are done assuming flat distribution of single muons in |y|<3.
 +====== Tracker using B=3T and R=1.25m ======
 +Here is a short description on how to check track resolution using [[http://atlaswww.hep.anl.gov/hepsim/detectorinfo.php?id=sidcc2|CEPC-sidcc2]] detector which has the SiD envelope for tracking (R=1.25 m), 25 um pitch size and 3 Tesla field.
 +The data are taken from [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull101|rfull101 dataset list]].
 +Here are the steps to check the resolution using single muons.
 +You will need this script {{:fcs:cepc:cepc_track_resolution.py|cepc_track_resolution.py}} and the input dataset
 +[[http://atlaswww.hep.anl.gov/hepsim/info.php?item=233|pgun_muon_eta3_pt150gev]]
 +<code bash>
 +bash   #  set bash if you haven't done this before, and make sure Java is installed.
 +wget http://atlaswww.hep.anl.gov/asc/jas4pp/download/current.php -O jas4pp.tgz
 +tar -zvxf jas4pp.tgz
 +source jas4pp/setup.sh # takes 5 sec for first-time optimization
 +hs-get pgun_muon_eta3_pt150gev%rfull101 data 2 500 # get 500 files in 2 threads
 +# download the python script shown above and run it as
 +fpad cepc_track_resolution.py
 +</code>
 +This script calculates the tracking resolution of this detector as shown below:
 +{{:fcs:cepc:cepc_resolution_rful101.png?400|}}
 +Here is the script that does sigma(1/pt). {{ :fcs:cepc:cepc_track_resolution_overpt.py |}}
 +{{:fcs:cepc:resolution_1overpt.png?400|}}
 +====== Tracker using B=3T and R=1.8m ======
 +A new CEPC-Si detector was created using B=3 and R=1.8m tracker, which can fits to the envelope of CEPC-ILD detector,
 +The new detector, called [[http://atlaswww.hep.anl.gov/hepsim/detectorinfo.php?id=sidcc3|CEPC-sidcc3]],
 + with modified tracker was used to create
 +[[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull102|rfull102 dataset list]].
 +The analysis of this data can be done exactly as before. The only difference is that you will need to download
 +the different dataset:
 +<code>
 +hs-get pgun_muon_eta3_pt150gev%rfull102 data 2 500 # get 500 files in 2 threads
 +</code>
 +The track resolutions are shown in
 +{{:fcs:cepc:cepc3_res1.png?400|}}
 +Here is the tracking resolution for 1/pt:
 +{{:fcs:cepc:cepc_track_resolution_overpt.png?400|}}
 +The data file is {{ :fcs:cepc:cepc_track_resolution_overpt.jdat |}}.
 +You can read jdat file in PyROOT using this simple macro {{ :fcs:cepc:make_root.py|script to read jdat files}}
 +====== Tracking in Barrel and Endcap ======
 +===== pT resolution =====
 +As before, this was done using B=3 and R=1.8m tracker and [[http://atlaswww.hep.anl.gov/hepsim/detectorinfo.php?id=sidcc3|CEPC-sidcc3]].
 +{{:fcs:cepc:cepc_track_resolution_overpt_barrel.png?400|}}
 +{{:fcs:cepc:cepc_track_resolution_overpt_endcap.png?400|}}
 +Data files are {{:fcs:cepc:cepc_track_resolution_overpt_barrel.jdat}},  {{:fcs:cepc:cepc_track_resolution_overpt_endcap.jdat}}
 +The results were created with the scripts {{:fcs:cepc:cepc_track_resolution_overpt_barrel.py}}, {{:fcs:cepc:cepc_track_resolution_overpt_endcap.py}}
 +===== d0 and z0 resolution =====
 +{{:fcs:cepc:cepc_track_resolution_d0_barrel.png?400|}}
 +{{:fcs:cepc:cepc_track_resolution_d0_endcap.png?400|}}
 +{{:fcs:cepc:cepc_track_resolution_z0_barrel.png?400|}}
 +{{:fcs:cepc:cepc_track_resolution_z0_endcap.png?400|}}
 +The files with data are:
 +  * {{ :fcs:cepc:cepc_track_resolution_z0_barrel.jdat |}}
 +  * {{ :fcs:cepc:cepc_track_resolution_z0_endcap.jdat |}}
 +  * {{ :fcs:cepc:cepc_track_resolution_d0_barrel.jdat |}}
 +  * {{ :fcs:cepc:cepc_track_resolution_d0_endcap.jdat |}}
 +===== Some physics plots =====
 +Here are a few plots illustrating physics performances. The figures have been done using fully identified muons and electrons (PandoraPFO). The following samples (tag rfull102) have been used:
 +  * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=148|gev250ee_pythia6_zpole_mumu]] - Z->mu+mu-
 +  * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=292|gev250ee_pythia8_higgs_mumu]] - Higgs ->mu+mu+ (all Higgs processes)
 +  * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e-
 +  * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=294|gev250ee_pythia8_zhiggs_nunumumu]] - Z0+Higgs-> nunu+mu+mu-
 +  * [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=295|gev250ee_pythia8_zhiggs_nunugg]] - Z0+Higgs-> nunu+gg
 +You can get the data (for Z0+Higgs-> nunu+mu+mu-, for example), as:
 +<code bash>
 +wget http://atlaswww.hep.anl.gov/hepsim/soft/hs-toolkit.tgz -O - | tar -xz;
 +source hs-toolkit/setup.sh
 +hs-get gev250ee_pythia8_zhiggs_nunumumu          # download ProMC (truth) files
 +hs-get gev250ee_pythia8_zhiggs_nunumumu%rfull102 # download SLCIO files for rfull102 tag
 +</code>
 +See [[http://atlaswww.hep.anl.gov/hepsim/doc/doku.php?id=hepsim:quick|ProMC manual]].
 +Now you  can convert ProMC data to STDHEP or LCIO (MCParticle) with full simulations using promc2stdhep or promc2lcio converters as discussed in [[hepsim:dev_full|ProMC to LCIO/STDHEP section]].
 +Here are a few plots that show the performance using [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=148|gev250ee_pythia6_zpole_mumu]]:
 +{{:fcs:cepc:zpeak_mumu_fit.png?400|}}
 +Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=292|gev250ee_pythia8_higgs_mumu]] - Higgs ->mu+mu+ (all Higgs processes)
 +{{:fcs:cepc:higgs_mumu_fit.png?400|}}
 +Here is the plot for [[http://atlaswww.hep.anl.gov/hepsim/info.php?item=146|gev250ee_pythia6_zpole_ee]] - Z-> e+e-
 +{{:fcs:cepc:zpeak_ee_fit.png?400|}}
 + --- //[[[email protected]|Sergei Chekanov]] 2017/09/07 17:04//
fcs/cepc/2017.txt · Last modified: 2024/07/01 21:25 by 127.0.0.1
