Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
fcs:fcchh [2017/04/16 13:38]
hepsim17
fcs:fcchh [2017/04/16 13:44]
hepsim17
Line 8: Line 8:
 **People:** A.Kotwal (Fermilab/Duke), L.Gray (Fermilab), S.Chekanov (ANL), J.Strube (PNNL), N.Tran (Fermilab), S-S. Yu (NCU), S.Sen (Duke), J.Repond (ANL) **People:** A.Kotwal (Fermilab/Duke), L.Gray (Fermilab), S.Chekanov (ANL), J.Strube (PNNL), N.Tran (Fermilab), S-S. Yu (NCU), S.Sen (Duke), J.Repond (ANL)
-The current goal of the studies is to understand physics requirements and design options using the "FCC-performance" detector, called "SiFCC". Unlike the FCChh-reference detector developed at CERN, the SiFCC detector:+The current goal of the studies is to understand physics requirements and design options using the "FCC-performance" detector [[https://arxiv.org/abs/1612.07291|[1]], called "SiFCC". Unlike the "FCChh-reference detectordeveloped at CERN, the SiFCC detector:
   * derived from the SiD concept (or CLIC)   * derived from the SiD concept (or CLIC)
Line 14: Line 14:
   * simple &  small (20% smaller than ATLAS)   * simple &  small (20% smaller than ATLAS)
   * includes detector features needed for 100 TeV collisions (12 lambda calorimeters, high-granularity tracker & calorimeters)    * includes detector features needed for 100 TeV collisions (12 lambda calorimeters, high-granularity tracker & calorimeters)
-  * Monte Carlo production since 2016+  * Monte Carlo production for tens-TeV physics since 2015
Line 26: Line 26:
   * **[[fcs:fcchh:tau| Z to tau+tau]]**    * **[[fcs:fcchh:tau| Z to tau+tau]]**
