Differences
fcs:fcchh [2017/04/16 13:38] hepsim17 |
fcs:fcchh [2017/04/16 13:45] hepsim17 |
Line 8: | Line 8: | ||
**People:** A.Kotwal (Fermilab/ | **People:** A.Kotwal (Fermilab/ | ||
- | The current goal of the studies is to understand physics requirements and design options using the "FCC-performance" | + | The current goal of the studies is to understand physics requirements and design options using the [[https:// |
* derived from the SiD concept (or CLIC) | * derived from the SiD concept (or CLIC) | ||
Line 14: | Line 14: | ||
* simple & small (20% smaller than ATLAS) | * simple & small (20% smaller than ATLAS) | ||
* includes detector features needed for 100 TeV collisions (12 lambda calorimeters, | * includes detector features needed for 100 TeV collisions (12 lambda calorimeters, | ||
- | * Monte Carlo production since 2016 | + | * Monte Carlo production |
Line 26: | Line 26: | ||
* **[[fcs: | * **[[fcs: | ||
