Differences
Link to this comparison view
Next revision
Previous revision
Next revision Both sides next revision
fcs:fcchh [2017/04/16 13:41]
hepsim17
fcs:fcchh [2017/04/16 13:44]
hepsim17
Line 8: Line 8:
 **People:** A.Kotwal (Fermilab/Duke), L.Gray (Fermilab), S.Chekanov (ANL), J.Strube (PNNL), N.Tran (Fermilab), S-S. Yu (NCU), S.Sen (Duke), J.Repond (ANL) **People:** A.Kotwal (Fermilab/Duke), L.Gray (Fermilab), S.Chekanov (ANL), J.Strube (PNNL), N.Tran (Fermilab), S-S. Yu (NCU), S.Sen (Duke), J.Repond (ANL)
-The current goal of the studies is to understand physics requirements and design options using the "FCC-performance" detector Initial performance studies of a general-purpose detector for multi-TeV physics at a 100 TeV pp collider +The current goal of the studies is to understand physics requirements and design options using the "FCC-performance" detector [[https://arxiv.org/abs/1612.07291|[1]], called "SiFCC". Unlike the "FCChh-reference detector" developed at CERN, the SiFCC detector:
-S.VChekanov, M. Beydler, A.V. Kotwal, L. Gray, S. Sen, N.V. Tran, S.-S. Yu, J. Zuzelski</ref> , called "SiFCC". Unlike the "FCChh-reference detector" developed at CERN, the SiFCC detector:+
   * derived from the SiD concept (or CLIC)   * derived from the SiD concept (or CLIC)
Line 27: Line 26:
   * **[[fcs:fcchh:tau| Z to tau+tau]]**    * **[[fcs:fcchh:tau| Z to tau+tau]]**
