Differences
hepsim:dev_fpadsim [2017/09/24 00:10] hepsim17 |
hepsim:dev_fpadsim [2017/09/24 02:06] hepsim17 |
Line 10: | Line 10: | ||
Many samples posted in HepSim are created with the package called " | Many samples posted in HepSim are created with the package called " | ||
- | The contributed authors of this package since 2015 are: | + | ) |
- | * D.Blyth (HEP/ANL) | + | |
- | * J.MacCormick (SLAC) | + | |
- | * W.Armstrong | + | |
- | * S.Chekanov (HEP/ANL) | + | |
- | * A.Kotwal (Duke) | + | |
- | * J.Strube (PNNL) | + | |
- | * J.Marshall (U.Cambridge) | + | |
Line 40: | Line 32: | ||
To process truth-level events with FpadSim, you need a few things: | To process truth-level events with FpadSim, you need a few things: | ||
- | * Singularity image with pre-built libraries | + | |
- | * Tag file | + | |
+ | The tag files should be processed with the simulation and reconstruction chain described above. | ||
+ | This can be done by using [[http:// | ||
+ | FPadSim software. | ||
+ | Here is the download link [[http:// | ||
+ | The image includes basic CentOS7 environment, | ||
+ | converters. | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | singularity | ||
+ | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. | ||
+ | Now you can process the tag file: | ||
+ | tar -zvxf rfull102.tgz | ||
+ | cd ilcsoft/ | ||
+ | ./TEST.sh # runs simple a test with single particles | ||
+ | The final file after pandoraPFA reconstruction with the name *hepsim.slcio" | ||
+ | Other files after simulation and track reconstruction steps will be located inside " | ||
+ | To process other promc files, download the required promc files and edit the file Test.sh | ||
+ | More information can be found in Section [[hepsim: | ||
+ | ===== Light version of image===== | ||
+ | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs: | ||
+ | ====== Contributions ====== | ||
+ | The contributed authors of this package since 2015 are: | ||
+ | * D.Blyth (HEP/ANL) | ||
+ | * J.MacCormick (SLAC) | ||
+ | * W.Armstrong | ||
+ | * S.Chekanov (HEP/ANL) | ||
+ | * A.Kotwal (Duke) | ||
+ | * J.Strube (PNNL) | ||
+ | * J.Marshall (U.Cambridge) | ||
