Differences
hepsim:dev_fpadsim [2017/09/24 00:11] hepsim17 |
hepsim:dev_fpadsim [2017/09/24 02:10] hepsim17 |
Line 32: | Line 32: | ||
To process truth-level events with FpadSim, you need a few things: | To process truth-level events with FpadSim, you need a few things: | ||
- | * Tag file with detector description | + | * Tag file with detector description. The concept of tag files is described in Sect.[[hepsim: |
- | * Singularity image with pre-built libraries to process | + | * Singularity image with pre-built libraries to process |
+ | The tag files should be processed with the simulation and reconstruction chain described above. | ||
+ | This can be done by using [[http:// | ||
+ | FPadSim software. | ||
+ | Here is the download link [[http:// | ||
+ | The image includes basic CentOS7 environment, | ||
+ | converters. | ||
+ | <code bash> | ||
+ | wget http:// | ||
+ | singularity | ||
+ | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. | ||
+ | Now you can process the tag file: | ||
+ | tar -zvxf rfull102.tgz | ||
+ | cd ilcsoft/ | ||
+ | ./TEST.sh # runs simple a test with single particles | ||
+ | The final file after pandoraPFA reconstruction with the name *hepsim.slcio" | ||
+ | Other files after simulation and track reconstruction steps will be located inside " | ||
+ | To process other promc files, download the required promc files and edit the file Test.sh | ||
+ | More information can be found in Section [[hepsim: | ||
+ | ===== Light version of FPadSim image===== | ||
+ | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs: | ||
Line 47: | Line 79: | ||
* A.Kotwal (Duke) | * A.Kotwal (Duke) | ||
* J.Strube (PNNL) | * J.Strube (PNNL) | ||
- | * J.Marshall (U.Cambridge | + | * J.Marshall (U.Cambridge) |
