Differences
hepsim:dev_fpadsim [2017/09/24 00:24] hepsim17 [Simulations with FPadSim] |
hepsim:dev_fpadsim [2017/09/24 02:10] hepsim17 |
Line 33: | Line 33: | ||
* Tag file with detector description. The concept of tag files is described in Sect.[[hepsim: | * Tag file with detector description. The concept of tag files is described in Sect.[[hepsim: | ||
- | * Singularity image with pre-built libraries to process | + | * Singularity image with pre-built libraries to process |
The tag files should be processed with the simulation and reconstruction chain described above. | The tag files should be processed with the simulation and reconstruction chain described above. | ||
- | This can be done by using [[http:// | + | This can be done by using [[http:// |
+ | FPadSim software. | ||
- | Here is the download link [[http:// | + | Here is the download link [[http:// |
The image includes basic CentOS7 environment, | The image includes basic CentOS7 environment, | ||
converters. | converters. | ||
- | wget http:// | + | wget http:// |
singularity | singularity | ||
- | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. | + | After the last line, the environment should be ready. For example, type "slic -h". It shows the available commands. |
- | You should also use the commands such as: | + | |
+ | Now you can process | ||
- | promc2lcio | + | wget http:// |
- | promc2stdhep | + | tar -zvxf rfull102.tgz |
+ | cd ilcsoft/ | ||
+ | ./TEST.sh # runs simple a test with single particles | ||
- | and many other. | + | The final file after pandoraPFA reconstruction with the name *hepsim.slcio" |
+ | Other files after simulation | ||
+ | To process | ||
+ | More information can be found in Section [[hepsim: | ||
+ | ===== Light version of FPadSim image===== | ||
+ | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec.[[fcs: | ||
- | Now | ||
====== Contributions ====== | ====== Contributions ====== | ||
Line 67: | Line 79: | ||
* A.Kotwal (Duke) | * A.Kotwal (Duke) | ||
* J.Strube (PNNL) | * J.Strube (PNNL) | ||
- | * J.Marshall (U.Cambridge | + | * J.Marshall (U.Cambridge) |
