Differences
hepsim:dev_hepsim [2020/06/26 21:19] hepsim17 |
hepsim:dev_hepsim [2020/06/26 21:20] hepsim17 |
Line 5: | Line 5: | ||
====== Linking event storage ====== | ====== Linking event storage ====== | ||
- | Monte Carlo files from any location can be published on [[https:// | + | Monte Carlo files from any location can be published on [[https:// |
HepSim is not a storage, but a catalog of files stored in multiple URL locations. It is your responsibility | HepSim is not a storage, but a catalog of files stored in multiple URL locations. It is your responsibility | ||
to maintain Monte Carlo data visible from HepSim. | to maintain Monte Carlo data visible from HepSim. | ||
Line 19: | Line 19: | ||
====== What do you need ====== | ====== What do you need ====== | ||
- | You need the following: | + | If you decide to publish Monte Carlo files (or make a mirror of the existing files), you need the following: |
* A web server that can hold your data (>1 TB for / | * A web server that can hold your data (>1 TB for / |
