Differences
hepsim:dev_singularity [2019/10/30 20:50] hepsim17 [Setting up Jas4pp] |
hepsim:dev_singularity [2019/10/30 20:52] hepsim17 [Light version of image] |
Line 60: | Line 60: | ||
Section [[hepsim: | Section [[hepsim: | ||
- | ==== Setting up Jas4pp ==== | + | |
+ | ====== Setting up Jas4pp | ||
One can setup a recent Jas4pp (with hs-tools) as | One can setup a recent Jas4pp (with hs-tools) as | ||
Line 74: | Line 75: | ||
====== HepSim tests ====== | ====== HepSim tests ====== | ||
+ | To setup simulation and reconstruction software from HepSim, you can use this commend: | ||
+ | <code bash> | ||
+ | singularity exec centos7hepsim.img | ||
+ | source / | ||
The docker container has a few basic tests that checks that everything works as expected. | The docker container has a few basic tests that checks that everything works as expected. | ||
Line 203: | Line 212: | ||
- | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec. [[fcs: | + | David Blyth created a lighter version of FPadSim image for EIC work described in Sec. [[fcs: |
