Differences
hepsim:dev_singularity [2019/10/30 20:52] hepsim17 [HepSim tests] |
hepsim:dev_singularity [2019/10/30 20:55] hepsim17 [Setting up Jas4pp] |
Line 65: | Line 65: | ||
One can setup a recent Jas4pp (with hs-tools) as | One can setup a recent Jas4pp (with hs-tools) as | ||
+ | singularity exec centos7hepsim.img | ||
source / | source / | ||
Line 212: | Line 213: | ||
- | David Blyth created a much lighter version of FPadSim image for EIC work described in Sec. [[fcs: | + | David Blyth created a lighter version of FPadSim image for EIC work described in Sec. [[fcs: |
