Differences
hepsim:dev_tags [2017/08/30 16:17] hepsim17 [How to submit detector tags] |
hepsim:dev_tags [2017/09/13 21:19] hepsim17 |
Line 4: | Line 4: | ||
====== Submitting tags ====== | ====== Submitting tags ====== | ||
- | ===== Reconstruction tags ===== | ||
Full detector simulations are created using the concept of tags, which are | Full detector simulations are created using the concept of tags, which are | ||
- | small (<3MB) files that include necessary information to convert truth-level files to final reconstructed events. All tags | + | small (<5 MB) files that include necessary information to convert truth-level files to final reconstructed events. All tags |
can be found in [[http:// | can be found in [[http:// | ||
In many cases we call them " | In many cases we call them " | ||
- | The reconstruction tag is associated with a file with the name "rfull[XXX].tgz", where [XXX] is a number | + | A reconstruction tag is associated with the file with the name **rfull[XXX].tgz**, where **[XXX]** is a number. |
- | (fast simulations have the files "rfast[XXX].tgz"). | + | Fast simulations have tags with the name **rfast[XXX].tgz**. |
- | The goal of the tag files: | + | The tag files are used for: |
- | * archive | + | * archiving |
- | * create a web page for HepSim | + | * creating the web page with the detector description |
- | * define | + | * defining |
- | * create | + | * creating |
+ | * feeding the HPC and grid jobs for simulation and reconstruction (for dockers & singularity images). | ||
+ | Reconstruction tags have unique names. There can be several reconstruction tags corresponding to a single detector, since simulation and reconstruction can be done using different software. | ||
+ | They are small files that are sourced by reconstruction software on grid or HPC. A file **rfull[XXX].tgz** | ||
+ | has everything you need to create LCIO/ROOT files with reconstructed events. | ||
- | Reconstruction | + | ====== Structure of tags ====== |
- | They are small files that are sourced by reconstruction software on grid or HPC. A file " | + | |
- | has everything you need to create LCIO/ROOT files with reconstructed events. Such files include the detector geometry, | + | In most cases, the directory inside rfull[XXX].tgz has this structure (for a detector called " |
Line 38: | Line 40: | ||
..... # other required files if needed | ..... # other required files if needed | ||
sifcch7 | sifcch7 | ||
- | - compact.xml | + | - compact.xml |
- | - other.xml ... # some other XML files with detector | + | - other.xml ... # some other XML files with detector |
- | - sifcch7.heprep | + | - sifcch7.heprep |
- | - sifcch7.lcdd | + | - sifcch7.lcdd |
- | - sifcch7.pandora # optional | + | - sifcch7.pandora # file for Pandora |
- | - sifcch7.json | + | - sifcch7.json |
- | - sifcch7.root | + | - sifcch7.root |
- | - sifcch7.html | + | - sifcch7.html |
- | - view1.png | + | - view1.png |
- | - view2.png | + | - view2.png |
- some config files | - some config files | ||
To see what is inside, download " | To see what is inside, download " | ||
- | In addition to the detector geometry, the tag files include | + | Such files include the detector geometry. |
+ | In addition to the detector geometry, the tag files include | ||
Generally, the form of this file is free, as long as it includes sufficient information | Generally, the form of this file is free, as long as it includes sufficient information | ||
to create reconstructed events. In many cases, the tag file has several scripts : A_RUN (to make a complete reconstruction chain) and TEST (to test on a few events). The software to run these scripts should be fully specified, and it is up to the author to make sure that one can use such files to run over events on a dedicated computing resource. | to create reconstructed events. In many cases, the tag file has several scripts : A_RUN (to make a complete reconstruction chain) and TEST (to test on a few events). The software to run these scripts should be fully specified, and it is up to the author to make sure that one can use such files to run over events on a dedicated computing resource. | ||
- | <note important> | + | <note important> |
when the tag files are sourced by reconstruction software on each node on HPC or grid, | when the tag files are sourced by reconstruction software on each node on HPC or grid, | ||
- | which are assumed to contain the needed software used in combination with rfullXXX.tgz files. | + | which are assumed to contain the needed software used in combination with **rfull[XXX].tgz** files. |
You should create the reconstruction tag if: | You should create the reconstruction tag if: | ||
- | * detector geometry | + | * detector geometry |
- | * detector geometry is the same, but configuration files and setup scripts | + | * detector geometry is the same, but configuration files and setup scripts |
- | HepSim provides a mechanism | + | HepSim provides a mechanism |
- | detector from rfull[XXX].tgz and builds an information detector page. Then you will see two entries: | + | detector from **rfull[XXX].tgz** and builds an information detector page. Then you will see two entries: |
- | As mentioned before, we leave the authors with the liberty to design rfull[XXX].tgz files. The only strict requirement is that they should have the directory with the detector, | + | As mentioned before, we leave the authors with the liberty to design |
The simulation and reconstruction scripts can include all the required | The simulation and reconstruction scripts can include all the required | ||
workflow to work together with the installed software (git, makefiles, wget commands etc). | workflow to work together with the installed software (git, makefiles, wget commands etc). | ||
<note tip> | <note tip> | ||
- | A tag file should have a directory with the detector name, and the "compact.xml" | + | A tag file should have a directory with the detector name, and the **compact.xml** file inside this directory. This structure helps automatically extract the detector for inclusion in HepSim. |
- | Please add compact.xml even if it is a dummy file not used for detector description.</ | + | Please add **compact.xml** even if it is a dummy file not used for detector description.</ |
After a tag file is uploaded, HepSim performs the following operations with this file: | After a tag file is uploaded, HepSim performs the following operations with this file: | ||
Line 90: | Line 93: | ||
First, request the account [[https:// | First, request the account [[https:// | ||
- | Then, go to [[http:// | + | Then, go to [[http:// |
