Differences
Both sides previous revision Previous revision | Next revision Both sides next revision | ||
hepsim:dev_tags [2017/09/13 18:00] hepsim17 |
hepsim:dev_tags [2017/09/13 21:19] hepsim17 |
Line 61: | Line 61: | ||
<note important> | <note important> | ||
when the tag files are sourced by reconstruction software on each node on HPC or grid, | when the tag files are sourced by reconstruction software on each node on HPC or grid, | ||
- | which are assumed to contain the needed software used in combination with **rfullXXX.tgz** files. | + | which are assumed to contain the needed software used in combination with **rfull[XXX].tgz** files. |
Line 80: | Line 80: | ||
<note tip> | <note tip> | ||
- | A tag file should have a directory with the detector name, and the **compact.xml** file inside this directory. This structure helps automatically extract the detector for inclusion in HepSim | + | A tag file should have a directory with the detector name, and the **compact.xml** file inside this directory. This structure helps automatically extract the detector for inclusion in HepSim. |
Please add **compact.xml** even if it is a dummy file not used for detector description.</ | Please add **compact.xml** even if it is a dummy file not used for detector description.</ | ||
Line 93: | Line 93: | ||
First, request the account [[https:// | First, request the account [[https:// | ||
- | Then, go to [[http:// | + | Then, go to [[http:// |
