Differences
Next revision | Previous revision Next revision Both sides next revision | ||
hepsim:dev_truth [2017/02/06 21:09] 127.0.0.1 external edit |
hepsim:dev_truth [2017/03/22 11:22] hepsim17 [Using converters] |
Line 1: | Line 1: | ||
- | [[community: | + | {{indexmenu_n> |
- | ====== Creating truth-level samples ====== | + | [[: |
- | HepSim is optimized to keep truth-level in the " | + | ====== Creating EVGEN ====== |
+ | HepSim is optimized to keep truth-level in the " | ||
Line 20: | Line 22: | ||
* lhe2promc | * lhe2promc | ||
* stdhep2promc | * stdhep2promc | ||
+ | * txt2promc | ||
+ | Look at the [[https:// | ||
- | Look at the [[asc: | + | One useful example showing how to read a text file with Monte Carlo events and fill correct |
+ | the example " | ||
====== Using Madgraph5====== | ====== Using Madgraph5====== |
