Differences
hepsim:dev_truth [2017/02/06 23:05] hepsim17 |
hepsim:dev_truth [2017/03/22 11:22] hepsim17 [Using converters] |
Line 3: | Line 3: | ||
- | ====== Creating | + | ====== Creating |
- | HepSim is optimized to keep truth-level in the " | + | HepSim is optimized to keep truth-level in the " |
Line 22: | Line 22: | ||
* lhe2promc | * lhe2promc | ||
* stdhep2promc | * stdhep2promc | ||
+ | * txt2promc | ||
- | Look at the [[asc: | + | Look at the [[https:// |
+ | One useful example showing how to read a text file with Monte Carlo events and fill correct ProMC file is given by | ||
+ | the example " | ||
====== Using Madgraph5====== | ====== Using Madgraph5====== |
