Differences
hepsim:hs-tools [2017/07/17 21:18] hepsim17 |
hepsim:hs-tools [2017/07/17 21:24] hepsim17 |
Line 3: | Line 3: | ||
- | ====== Using HS-TOOLS ====== | + | ====== Using hs-toolkit |
Line 13: | Line 13: | ||
* [[https:// | * [[https:// | ||
- | See [[http:// | + | ====== |
- | Look at [[http:// | + | |
- | ====== Quick start ====== | + | |
Install the hs-toolkit using the " | Install the hs-toolkit using the " | ||
Line 36: | Line 33: | ||
This package is used for download, view and analyse HepSim files (truth-level only). | This package is used for download, view and analyse HepSim files (truth-level only). | ||
To analyse (*.lcio) files with Geant4 simulations, | To analyse (*.lcio) files with Geant4 simulations, | ||
- | [[http:// | + | [[http:// |
+ | include more software component to work with LCIO files. | ||
+ | To analyse ROOT files with fast simulations, | ||
+ | ====== Downloading files with hs-toolkit ====== | ||
+ | This topic was described in [[http:// | ||
+ | ====== Analysing events with hs-toolkit ====== | ||
+ | ====== Java API hs-toolkit ====== | ||
+ | See [[http:// | ||
+ | ====== Validation scripts ====== | ||
+ | hs-toolkit is used to run the scripts located in [[http:// | ||
