Differences
hepsim:hs-tools [2017/07/17 21:21] hepsim17 |
hepsim:hs-tools [2020/05/22 02:49] hepsim17 |
Line 10: | Line 10: | ||
- | * [[http://jwork.org/dmelt/| DMelt (community version)]] | + | * [[https://datamelt.org/ |
* [[https:// | * [[https:// | ||
- | See [[http:// | ||
- | Look at [[http:// | ||
====== Installing hs-toolkit ====== | ====== Installing hs-toolkit ====== | ||
Line 22: | Line 19: | ||
bash # set to bash if needed | bash # set to bash if needed | ||
- | wget http:// | + | wget https:// |
source hs-toolkit/ | source hs-toolkit/ | ||
Line 40: | Line 37: | ||
To analyse ROOT files with fast simulations, | To analyse ROOT files with fast simulations, | ||
+ | <note tip>Note that you can also use the [[hepsim: | ||
+ | hs-tools commands</ | ||
====== Downloading files with hs-toolkit ====== | ====== Downloading files with hs-toolkit ====== | ||
- | This topic was described in [[http:// | + | This topic was described in [[https:// |
====== Analysing events with hs-toolkit ====== | ====== Analysing events with hs-toolkit ====== | ||
+ | ====== Java API hs-toolkit ====== | ||
+ | See [[https:// | ||
+ | ====== Validation scripts ====== | ||
+ | hs-toolkit is used to run the scripts located in [[https:// | ||
