Differences
hepsim:jas4pp [2021/02/13 23:12] hepsim17 [Reading LCIO files] |
hepsim:jas4pp [2021/02/17 00:10] hepsim17 [Jas4pp description] |
Line 41: | Line 41: | ||
* Downloading and searching HepSim data | * Downloading and searching HepSim data | ||
* Processing ProMC files from HepSim | * Processing ProMC files from HepSim | ||
+ | * Processing ROOT files created by the Delphes program for fast simulation | ||
* Running over SLCIO files with Geant4 simulated / reconstructed events. | * Running over SLCIO files with Geant4 simulated / reconstructed events. | ||
* Data analysis (jets, physics vectors, histogram packages) | * Data analysis (jets, physics vectors, histogram packages) | ||
- | * Visualisation | + | * Visualization |
You can find more details in [[https:// | You can find more details in [[https:// | ||
Line 198: | Line 199: | ||
- | Jas4pp natively reads ROOT files including files created using ROOT 6 (ROOT3, 4 and 5 are also supported). For example, one can read ROOT trees/ntuples. | + | Jas4pp natively reads commonly used objects and data structures from [[https:// |
- | One can find some examples in the directory " | + | ROOT files can be loaded using the Jas4pp menu [File]-[Open data source]-[Root file] (*.root). |
+ | In addition, one can work with ROOT files using Python/Jython or Groovy scripts. | ||
+ | One can find some examples in the directory " | ||
<hidden Show example of a Python code here> | <hidden Show example of a Python code here> | ||
Line 308: | Line 312: | ||
You will see the browsers: | You will see the browsers: | ||
- | {{:asc: | + | {{:hepsim: |
The script that call these browsers | The script that call these browsers | ||
- | Jas4pp does not support ROOT files with complex objects created using ROOT 6, i.e. TH1D, TH2D and TGraph. | ||
====== Using GUI mode ====== | ====== Using GUI mode ====== |
