Differences
Next revision | Previous revision Next revision Both sides next revision | ||
hepsim:pgun [2017/02/06 21:17] 127.0.0.1 external edit |
hepsim:pgun [2017/02/07 02:33] hepsim17 |
Line 1: | Line 1: | ||
- | [[hepsim|<< back to HepSim manual]] | + | |
+ | {{indexmenu_n> | ||
+ | [[:|<< back to HepSim manual]] | ||
====== Creating single particle samples ====== | ====== Creating single particle samples ====== | ||
Single particle samples are created using the ProMC Java package. | Single particle samples are created using the ProMC Java package. | ||
- | Here is an example how to make single particle sample using Jython {{:community: | + | Here is an example how to make single particle sample using Jython {{: |
You can use [[https:// | You can use [[https:// |
