Differences
Both sides previous revision Previous revision | Next revision Both sides next revision | ||
hepsim:pgun [2017/02/06 23:05] hepsim17 |
hepsim:pgun [2017/02/07 02:33] hepsim17 |
Line 7: | Line 7: | ||
Single particle samples are created using the ProMC Java package. | Single particle samples are created using the ProMC Java package. | ||
- | Here is an example how to make single particle sample using Jython {{:community: | + | Here is an example how to make single particle sample using Jython {{: |
You can use [[https:// | You can use [[https:// |
