Differences
hepsim:quick [2017/07/17 21:25] hepsim17 |
hepsim:quick [2018/08/30 00:50] hepsim17 |
Line 13: | Line 13: | ||
- | This creates the directory " | + | This creates the directory " |
- | [[https:// | + | [[https:// |
- | You can view the commands by typing: | + | You can view the commands |
- | hs-help | + | bash> |
- | This package is used for download, view and analyse HepSim files (truth-level | + | The directory contains several bash scripts for Linux/Mac, and Windows batch (BAT) files to process events on Windows OS. |
- | To analyse (*.lcio) files with Geant4 simulations, | + | The package is used for download, view and analyze |
- | [[http:// | + | |
+ | <note tip> | ||
+ | Use [[http:// | ||
+ | (*.lcio) files with Geant4 simulations. | ||
+ | This program can also be used for truth-level records in the [[https:// | ||
+ | To analyse ROOT files with fast simulations, | ||
====== Finding data files ====== | ====== Finding data files ====== | ||
Line 57: | Line 62: | ||
- | hs-ls [setname] simple | + | hs-ls [name] simple |
- | hs-ls [setname] simple-url > input_url.list # make list with URL from the main server | + | hs-ls [name] simple-url > input_url.list # make list with URL from the main server |
- | where [setname] is the name of dataset. You can also use a URL if you want to create a list of files from certain (mirror) servers. | + | where [name] is the name of dataset. You can also use a URL if you want to create a list of files from certain (mirror) servers. |
====== Searching for datasets ====== | ====== Searching for datasets ====== | ||
Line 227: | Line 232: | ||
This command brings up a GUI window to look at separate events. You should forward X11 to see the GUI. For Windows: download the file [[http:// | This command brings up a GUI window to look at separate events. You should forward X11 to see the GUI. For Windows: download the file [[http:// | ||
+ | <note tip>If you use Windows OS, click " | ||
Line 239: | Line 247: | ||
====== Monte Carlo logfile ====== | ====== Monte Carlo logfile ====== | ||
- | You can work with ProMC using the standard Linux commands, such as " | + | Each ProMC/ProIO file includes a logfile from the Monte Carlo generator. Show this file on the screen as: |
+ | hs-log [file] | ||
+ | where [file] is either a ProMC or ProIO file (you can use URL instead of the full path on the local computer). | ||
+ | In the case of ProMC files, one can use the standard Linux commands, such as " | ||
Line 323: | Line 338: | ||
It opens this file for editing. One can run it by clicking on the " | It opens this file for editing. One can run it by clicking on the " | ||
It also provides an interactive Jython shell. | It also provides an interactive Jython shell. | ||
+ | <note tip>If you use Windows OS, click the file " | ||
When possible, use the downloaded ProMC files, rather than streaming the data over the network. | When possible, use the downloaded ProMC files, rather than streaming the data over the network. |
