Differences
hepsim:resources [2017/02/07 02:49] hepsim17 |
hepsim:resources [2017/06/16 14:45] hepsim17 |
Line 1: | Line 1: | ||
+ | {{indexmenu_n> | ||
+ | HepSim event data samples are created using: | ||
====== Used resources ====== | ====== Used resources ====== | ||
- | There is a number | + | * BlueGene/Q supercomputer |
- | open-source particle simulations and outreach. Help from undergraduate | + | * [[https:// |
- | HepSim projects can expand your programming | + | |
- | data analysis. HepSim uses the same general software and tools as for the ongoing and future experiments. | + | * Argonne’s Laboratory Computing Resource Center (LCRC) (" |
- | is that HepSim packages are not proprietorial, | + | * ATLAS Analysis support (ASC) cluster at HEP/ANL |
- | to worry about permissions from HEP experiments/collaborations to publish your own research. | + | |
+ | The file storage | ||
+ | * STASH2 storage at OSG CI Connect | ||
+ | * FAXBOX storage at ATLAS Connect | ||
+ | * [[https://www.nersc.gov/ | ||
+ | * MC.HEP server at ASC ANL | ||
- | Here are several open tasks: | + | This repository was created following |
+ | the guidelines and principles of the | ||
+ | [[http:// | ||
+ | for unclassified and otherwise unrestricted scientific data in digital formats. | ||
- | * Improve the converter " | ||
- | * The FCC-hh detector has about 300 overlaps in the inner/outer tracker (support structures are shifted, overlaps with the beam pipe). The task is to correct compact.xml file into GDML file, and check for overlaps using the existing tools included into ROOT. | ||
- | * Detector and events should be viewed using a Web event browser based on WebGL or other methods. Please look at the [[http:// | ||
- | * Improvements for the graphics of [[https:// | ||
- | * Improvements in HepRApp code. Currently, this Java-based viewer it is not actively supported (and the source code is not available). But the tool gives a sample method to view events | ||
- | Of course, you can do a lot of your own research, including physics performance studies using truth-level, | + | ====== Acknowledgment ====== |
- | You are only limited by your own imagination. | + | |
- | Please contact [email protected] if you are interested in these tasks. | ||
- | | + | This work is supported |
+ | Operator of Argonne National Laboratory (``Argonne'' | ||
+ | Argonne, a U.S. Department of Energy Office of Science laboratory, | ||
+ | is operated under Contract No. DE-AC02-06CH11357. | ||
+ | This research used resources of the Argonne Leadership Computing Facility at Argonne | ||
+ | National Laboratory, which is supported by the Office of Science of the U.S. Department of Energy under contract DE-AC02-06CH11357. |
