Differences
hepsim:usage [2017/02/06 22:51] hepsim17 |
hepsim:usage [2017/02/07 02:29] hepsim17 |
Line 3: | Line 3: | ||
[:|<< back to HepSim manual]] | [:|<< back to HepSim manual]] | ||
The Monte Carlo files (truth level, fast simulations and full simulations) | The Monte Carlo files (truth level, fast simulations and full simulations) | ||
Line 13: | Line 13: | ||
You have several choices for data analysis: | You have several choices for data analysis: | ||
- | * Using the hs-tools package | + | * Using the hs-tools package. It is designed for downloading files and processing truth-level files using Python/ |
* Using [[http:// | * Using [[http:// | ||
- | * Using C++/ROOT. If you run over ProMC (truth-level) files, look at the manual [[asc: | + | * Using C++/ROOT. If you run over ProMC (truth-level) files, look at the manual [[https:// |
Some analysis examples implemented in Python and C++ can be found in [[fcs: | Some analysis examples implemented in Python and C++ can be found in [[fcs: |
