Differences
hepsim:usage_analysis [2017/07/17 19:49] hepsim17 |
hepsim:usage_analysis [2018/07/28 13:43] hepsim17 [Using ProIO files] |
Line 21: | Line 21: | ||
* Using Java web start from the browser. | * Using Java web start from the browser. | ||
Line 76: | Line 76: | ||
This methods takes file list, and identify pT ranges given between the strings " | This methods takes file list, and identify pT ranges given between the strings " | ||
- | ====== Reading the file header | + | |
+ | ====== Using ProMC files ====== | ||
+ | ===== Reading the file header ===== | ||
To read data from a ProMC file, you will need these statements: | To read data from a ProMC file, you will need these statements: | ||
Line 98: | Line 102: | ||
- | ====== Reading the event records | + | ===== Reading the event records ===== |
Line 228: | Line 232: | ||
Look at a typical example of jet clustering in the [[http:// | Look at a typical example of jet clustering in the [[http:// | ||
- | ====== Event statistics | + | ===== Event statistics ===== |
Before closing ProMC file, you may need to access event statistics, cross sections and errors on cross sections. | Before closing ProMC file, you may need to access event statistics, cross sections and errors on cross sections. | ||
Line 246: | Line 250: | ||
+ | ====== Using ProIO files ====== | ||
+ | ProIO files have their own API (https:// | ||
+ | It is at early stage of development. You can look at example of how to use ProIO here [http:// | ||
====== Plots and histograms ====== | ====== Plots and histograms ====== |
