Both sides previous revision
Previous revision
Next revision
Previous revision
Next revision
Both sides next revision
hepsim:usage_detectors [2017/02/06 23:50] hepsim17 |
hepsim:usage_detectors [2017/02/13 19:10] hepsim17 [Full (Geant4) simulations] |
====== Detector description and reconstructed tags ====== | ====== Detector descriptions ====== |
Here we describe available reconstruction tags used by HepSim. | Here we describe available reconstruction tags used by HepSim. |
The file format is ROOT. | The file format is ROOT. |
Look at [[community:hepsim:usage_fast|this description]]. | Look at [[:hepsim:usage_fast|this description]]. |
====== Full (Geant4) simulations ====== | ====== Full (Geant4) simulations ====== |
| rfull012 | Same as SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull012 | Same as SiFFC-v7, but super fine HCAL cells. HCAL cells are 1x1cm (vs 5x5 cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.heprep|sifcch10.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch10/sifcch10.gdml.gz|sifcch10.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull012| find=rfull012]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| rfull013 | Same as SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | | | rfull013 | Same as SiFFC-v7, but super fine HCAL (1x1cm) and ECAL (3x3mm) cells (vs 5x5 cm and 2x2cm for SiFFC-v7) | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.heprep|sifcch11.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull013| find=rfull013]] | {{:hepsim:sifcc7.png?200|SiFCC-v8}} | |
| | rfull014 | Same as SiFFC-v7, but relaxed hit cuts for HCAL and ECAL | [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.html|description]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch12/sifcch12.heprep|sifcch12.heprep]], [[http://atlaswww.hep.anl.gov/hepsim/soft/detectors/sifcch11/sifcch11.gdml.gz|sifcch11.gdml.gz]] | [[http://atlaswww.hep.anl.gov/hepsim/list.php?find=rfull014| find=rfull014]] | {{:hepsim:sifcc7.png?200|SiFCC-v12}} | |
The output file format is LCIO. The files can be read as explained [[community:hepsim:usage_full|here]]. To view geometries using | The output file format is LCIO. The files can be read as explained [[:hepsim:usage_full|here]]. To view geometries using |
ROOT geometry package, run these commands: | ROOT geometry package, run these commands: |
